Устсан, гэмтсэн system datafile -ийг нөөцөөс сэргээх
system01.dbf файлыг нөөцөөс сэргээж туршицгаая.
Файлыг устгана.
[oracle@node214 ~]$
[oracle@node214 ~]$ . oraenv
ORACLE_SID = [DB11G] ?
The Oracle base for ORACLE_HOME=/u01/app/oracle/product/11.2.0/db_1 is /u01/app/oracle
[oracle@node214 ~]$
[oracle@node214 ~]$ cd /u01/app/oracle/oradata/DB11G/
drwxr-x--- 2 oracle oinstall      4096 Jan 27 19:35 .
drwxr-x--- 5 oracle oinstall      4096 Jan 23 10:17 ..
-rw-r----- 1 oracle oinstall   9748480 Feb  1 01:46 control01.ctl
-rw-r----- 1 oracle oinstall 209723392 Feb  1 01:46 example01.dbf
-rw-r----- 1 oracle oinstall  52429312 Jan 29 07:02 redo01.log
-rw-r----- 1 oracle oinstall  52429312 Jan 29 07:02 redo02.log
-rw-r----- 1 oracle oinstall  52429312 Jan 29 07:06 redo03.log
-rw-r----- 1 oracle oinstall 671096832 Feb  1 01:46 sysaux01.dbf
-rw-r----- 1 oracle oinstall 754982912 Feb  1 01:46 system01.dbf
-rw-r----- 1 oracle oinstall  30416896 Feb  1 01:00 temp01.dbf
-rw-r----- 1 oracle oinstall 524296192 Feb  1 01:46 test_assm01.dbf
-rw-r----- 1 oracle oinstall 524296192 Feb  1 01:46 test_mssm01.dbf
-rw-r----- 1 oracle oinstall 104865792 Feb  1 01:46 undotbs01.dbf
-rw-r----- 1 oracle oinstall 360456192 Feb  1 01:46 users01.dbf
[oracle@node214 DB11G]$ rm system01.dbf
[oracle@node214 DB11G]$ ls -la
total 3270008
drwxr-x--- 2 oracle oinstall      4096 Feb  1 03:14 .
-rw-r----- 1 oracle oinstall   9748480 Feb  1 03:15 control01.ctl
-rw-r----- 1 oracle oinstall 209723392 Feb  1 03:12 example01.dbf
-rw-r----- 1 oracle oinstall 671096832 Feb  1 03:12 sysaux01.dbf
-rw-r----- 1 oracle oinstall 754982912 Feb  1 03:15 system01.dbf
-rw-r----- 1 oracle oinstall  30416896 Feb  1 03:12 temp01.dbf
-rw-r----- 1 oracle oinstall 524296192 Feb  1 03:12 test_assm01.dbf
-rw-r----- 1 oracle oinstall 524296192 Feb  1 03:12 test_mssm01.dbf
-rw-r----- 1 oracle oinstall 104865792 Feb  1 03:12 undotbs01.dbf
-rw-r----- 1 oracle oinstall 360456192 Feb  1 03:12 users01.dbf
Dictionary-с мэдээлэл авахыг оролдоцгооё. Dictionary мэдээллүүд system tablespace-т хадгалагддаг билээ.
[oracle@node214 ~]$
[oracle@node214 ~]$ sqlplus / as sysdba
SQL*Plus: Release 11.2.0.1.0 Production on Wed Feb 1 03:13:28 2017
Copyright (c) 1982, 2009, Oracle.  All rights reserved.
Connected to:
Oracle Database 11g Enterprise Edition Release 11.2.0.1.0 - 64bit Production
With the Partitioning, OLAP, Data Mining and Real Application Testing options
SQL> desc dict;
ERROR:
ORA-00604: error occurred at recursive SQL level 1
ORA-01116: error in opening database file 1
ORA-01110: data file 1: '/u01/app/oracle/oradata/DB11G/system01.dbf'
ORA-27041: unable to open file
Linux-x86_64 Error: 2: No such file or directory
Additional information: 3
system01.dbf файлыг нээж чадахгүй байна гэсэн алдаа гарч байна. Бид өмнө уг файлыг устгасан байгаа билээ. Тиймээс баазыг унтрааж mount горимд эхлүүлье. Учир нь controlfile-ийг нээж datafile-ийн мэдээллийг авч нээснээр open горимд шилждэг билээ.
SQL> shu abort
ORACLE instance shut down.
SQL> startup mount
ORACLE instance started.
Total System Global Area  217157632 bytes
Fixed Size		    2211928 bytes
Variable Size		  159387560 bytes
Database Buffers	   50331648 bytes
Redo Buffers		    5226496 bytes
Database mounted.
Одоо бид шаардлагатай датафайлтай ажиллах боломж бүрдэж байна. Тиймээс нөөцлөлтөөс сэргээе. rman ашиглана.
[oracle@node214 ~]$
[oracle@node214 ~]$ rman target /
Recovery Manager: Release 11.2.0.1.0 - Production on Wed Feb 1 03:14:11 2017
Copyright (c) 1982, 2009, Oracle and/or its affiliates.  All rights reserved.
connected to target database: DB11G (DBID=403682774, not open)
RMAN> restore datafile 1;
Starting restore at 01-FEB-17
using target database control file instead of recovery catalog
allocated channel: ORA_DISK_1
channel ORA_DISK_1: SID=20 device type=DISK
channel ORA_DISK_1: starting datafile backup set restore
channel ORA_DISK_1: specifying datafile(s) to restore from backup set
channel ORA_DISK_1: restoring datafile 00001 to /u01/app/oracle/oradata/DB11G/system01.dbf
channel ORA_DISK_1: reading from backup piece /u01/app/oracle/flash_recovery_area/DB11G/backupset/2017_01_28/o1_mf_nnndf_TAG20170128T054242_d8qhply9_.bkp
channel ORA_DISK_1: piece handle=/u01/app/oracle/flash_recovery_area/DB11G/backupset/2017_01_28/o1_mf_nnndf_TAG20170128T054242_d8qhply9_.bkp tag=TAG20170128T054242
channel ORA_DISK_1: restored backup piece 1
channel ORA_DISK_1: restore complete, elapsed time: 00:00:55
Finished restore at 01-FEB-17
RMAN>
Файлыг сэргээсэн тул одоо тухайн үеэс хойшхи мэдээллийг лог файлаас татах шаардлагатай. Тиймээс уг үйлдлийг хийцгээе.
RMAN> recover datafile 1;
Starting recover at 01-FEB-17
using channel ORA_DISK_1
starting media recovery
archived log for thread 1 with sequence 28 is already on disk as file /u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_28/o1_mf_1_28_d8qo5srf_.arc
archived log for thread 1 with sequence 29 is already on disk as file /u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_28/o1_mf_1_29_d8rff6qv_.arc
archived log for thread 1 with sequence 30 is already on disk as file /u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_29/o1_mf_1_30_d8t8zy3h_.arc
archived log for thread 1 with sequence 31 is already on disk as file /u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_30/o1_mf_1_31_d8woywy6_.arc
archived log for thread 1 with sequence 32 is already on disk as file /u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_30/o1_mf_1_32_d8xchc3k_.arc
archived log for thread 1 with sequence 33 is already on disk as file /u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_30/o1_mf_1_33_d8yksj0g_.arc
archived log for thread 1 with sequence 34 is already on disk as file /u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_31/o1_mf_1_34_d8z0xlrg_.arc
archived log for thread 1 with sequence 35 is already on disk as file /u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_31/o1_mf_1_35_d906h576_.arc
archived log for thread 1 with sequence 36 is already on disk as file /u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_31/o1_mf_1_36_d90xgvx6_.arc
archived log for thread 1 with sequence 37 is already on disk as file /u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_31/o1_mf_1_37_d91656v1_.arc
archived log for thread 1 with sequence 38 is already on disk as file /u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_02_01/o1_mf_1_38_d91f52sf_.arc
archived log file name=/u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_28/o1_mf_1_28_d8qo5srf_.arc thread=1 sequence=28
archived log file name=/u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_28/o1_mf_1_29_d8rff6qv_.arc thread=1 sequence=29
archived log file name=/u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_29/o1_mf_1_30_d8t8zy3h_.arc thread=1 sequence=30
archived log file name=/u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_30/o1_mf_1_31_d8woywy6_.arc thread=1 sequence=31
archived log file name=/u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_30/o1_mf_1_32_d8xchc3k_.arc thread=1 sequence=32
archived log file name=/u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_30/o1_mf_1_33_d8yksj0g_.arc thread=1 sequence=33
archived log file name=/u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_31/o1_mf_1_34_d8z0xlrg_.arc thread=1 sequence=34
archived log file name=/u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_31/o1_mf_1_35_d906h576_.arc thread=1 sequence=35
archived log file name=/u01/app/oracle/flash_recovery_area/DB11G/archivelog/2017_01_31/o1_mf_1_36_d90xgvx6_.arc thread=1 sequence=36
media recovery complete, elapsed time: 00:00:28
Finished recover at 01-FEB-17
RMAN>
Файл бүрэн сэргэлээ. Тиймээс баазыг нээцгээе.
SQL> alter database open;
Database altered.
SQL> desc dict;
 Name					   Null?    Type
 TABLE_NAME					    VARCHAR2(30)
 COMMENTS					    VARCHAR2(4000)
