Oracle 12c Cloud Control-ийг суулгах явцад OMS Configuraton дээр алдаа өгөх болон Alert log дотор доорх:
INFO: oracle.sysman.top.oms:java.sql.SQLException: ORA-14400: inserted partition key does not map to any partition
INFO: oracle.sysman.top.oms:ORA-06512: at “SYSMAN.EM_SELF_UPDATE”, line 1537
INFO: oracle.sysman.top.oms:ORA-06512: at line 1
INFO: oracle.sysman.top.oms:OMSCA-ERR:Post deploy operations failed. Check the trace file:/u01/app/oracle/product/Middleware/oms/cfgtoollogs/omsca/omsca_20140402160051.log
Check the OMS Configuration Assistant logs at: /u01/app/oracle/product/Middleware/oms/cfgtoollogs/omsca
INFO: oracle.sysman.top.oms:The plug-in OMS Configuration has failed its perform method
лог бичигдсэн тохиолдолд database руу SYSMAN хэрэглэгчээр хандан доорх коммандыг ажиллуулан “Retry” товч дээр дарж суулгацыг үргэлжлүүлнэ.
SQL> exec gc_interval_partition_mgr.partition_maintenance;
SQL> exec mgmt_audit_admin.add_audit_partition;
