Баазыг устгах (drop database manually)
dbca комманд ашиглаад баазыг хялбархан устгаж болно. Харин танд зөвхөн коммандын мөр байгаа тохиолдолд хэрхэн устгах талаар сонирхуулъя.
[oracle@node215 ~]$ sqlplus / as sysdba
SQL> select name from v$datafile;
NAME
/u01/app/oracle/oradata/orcl/system01.dbf
/u01/app/oracle/oradata/orcl/sysaux01.dbf
/u01/app/oracle/oradata/orcl/undotbs01.dbf
/u01/app/oracle/oradata/orcl/users01.dbf
SQL> shu immediate
Database closed.
Database dismounted.
ORACLE instance shut down.
SQL> startup nomount restrict;
ORACLE instance started.
Total System Global Area  217157632 bytes
Fixed Size		    2251816 bytes
Variable Size		  159384536 bytes
Database Buffers	   50331648 bytes
Redo Buffers		    5189632 bytes
SQL> alter database mount;
Database altered.
SQL> drop database;
Database dropped.
Disconnected from Oracle Database 11g Enterprise Edition Release 11.2.0.4.0 - 64bit Production
With the Partitioning, OLAP, Data Mining and Real Application Testing options
[oracle@node215 ~]$ rm -Rf /u01/app/oracle/oradata/orcl/
[oracle@node215 ~]$ rm -Rf /u01/app/oracle/admin/orcl/
[oracle@node215 ~]$ rm -Rf /u01/app/oracle/fast_recovery_area/orcl/
Үүний дараагаар /etc/oratab файлаас уг баазын харгалзах мөрийг устгана.
